chr_
Jul 01, 2015Explorer
RSD559 wrote:
chr$, is that for the old VB function to represent a character by it's character code, or are your initials chr and you're rich?
Anyway, thanks for the pictures. I'm going to use the 3" pipe idea, and the vents as well. My trailer came with one 27 size battery, so I can't double it up in the box. And, mine is not designed to remove easily. I have nothing except the battery brackets under it. Where did you get the little vents? Thanks again.
Far from rich. You are probably the only person in 10+ years who figured it out.
I used to sign CHR$(67) which is AASCII for the letter "C"
The little vents actually came off of a crate that a piece of machinery came in from Germany. They are sheetmetal squares with three louvers punched in them. I think a custom hot rod shop might be able to make them on a piece of sheetmetal for you pretty cheap. Also, Hoffman industrial enclosures makes one that is similar, and I think Mc Master Carr carries Hoffman.
