Coolerman
Oct 20, 2015Explorer
"How did you mount your LED light strip under your rig? Are they just using the 3M tape and stuck to the black coroplast under your trailer, or did you put them on the beam somehow?
Mine are the kind with sticky tape on the back side the the LED strip. I wiped off the bottom of the frame beam with a soapy rag then used alcohol prep pads to get the remaining crud off then stuck the LEDS to the bottom of the frame.
The E-Bay kits (5 Meters) were exactly the correct length for the Sonic. After a week they came loose in a couple of places so I used clear Gorilla tape to stick them back. They survived a 2600 mile round trip to Colorado!
