rrev
Apr 18, 2016Explorer
The trick to the 3M tape is prep. Surface has to be nearly surgically clean and the use of adhesion promoter helps tremendously. You can use pvc primer, like for plastic pipes. Just make sure you tape off adjacent areas so you don't stain surfaces you don't want it on.
