dewey02
Mar 08, 2018Explorer II
Bob 1870 wrote:
Dual Axle Wheel Chocks
I know I know...this has been done a thousand times. I could never find a drawing to answer a few questions I had. So I made this up. I made set of these today and they are pretty slick. I am going o see if I can get the turn knobs (something like these:
https://www.mcmaster.com/#threaded-knobs/=x5lxzi.) I hope it helps someone else. The narrow part of the block was 1/2 grater than the distance between the tires.
Instead of threaded turn knobs, just use a pipe clamp.
Very easy to adjust, and you can have the crank on top or on bottom, whatever is easiest for your trailer.
44,071 PostsLatest Activity: Aug 30, 2026
