Yellerledbetty
May 30, 2021Explorer
Hi All,
Have a 2014 OutdoorsRV BlackRock Travel Trailer (external link to images below) and I am looking to remove the 'shirt ward' from above the rear 'Standard Double Bed' and expand the 'Combo OHD Bunk w/ pads' to allow for both our young-ish kids to sleep up there. I have the carpentry skills to DIY this but looking for some thoughts.
Ideally I'd like to retain the hinged OHD feature - bunk currently hinges between OHD storage and lay-flat bunk - but expand that storage and sleeping capacity by moving the plane of that hinge to (approximately) the front face of the 'pantry' so it would fold flat for a full-sized bunk (same dimensions s the queen below it) while providing some additional volume to the OHD feature.
I don't anticipate a big issue with removing the 'shirt ward' and would really only have to ensure I secure framing to whatever 'studs' would be further out along that pantry wall at the toe of the bed and similarly in the shared wall of the bathroom along the right side of the sleeping area. I dont expect that I would need to install 'vertical supports' for the portion of the expanded bunk - the length spanning between the pantry and bathroom walls if I build it w/ sufficiently robust dimensional lumber.
Perhaps the removal of the 'shirt ward' could also facilitate the simultaneous use of the single-bunk being + OHD feature byway of having a removable door (or secured-open) that one of the kids could crawl through and use w/o having to un-pin the vertical divider and flatten it out.
Thanks for any tips or links you might have!
I hope the link to the images works - I have not had luck in posting links via the upload-tool noted by another member.
https://www.rangitschbrosrv.com/inventory-slideshow/index.php?id=856&rv_title=2014+OUTDOORS+RV+BLACK+ROCK+17B
Regards,
Bri@n
Regards,
Bri@n
44,070 PostsLatest Activity: Sep 18, 2026
