wintersun
May 06, 2013Explorer II
I would highly recommend getting top quality aftermarket gaskets and not replacing the ones on the engine with the ones from GM. Labor cost will be the same and GM head gaskets are notorious for failing.
If coolant is getting into the intake manifold the first symptom is a loss of power, particularly when the engine is cold as the coolant is inhibiting combustion.
