- beemerphile1ExplorerI use either my Dewalt 18v drill or my Ryobi 18V drill, for this use they both do fine although the Dewalt is a better quality drill.
yrusoslo wrote:
Look into a cordless impact gun
Please don't, I and the rest of the campground don't want to listen to the racket. - Go to Home Depot or Lowe's and by something within your price range. Dewalt is my preference.
If you are only buying it to use in the RV for the jacks, then maybe something cheap from harbor Freight is OK, since the price is lower. - colliehaulerExplorer III
SoundGuy wrote:
I used a Makita 9.6 cordless drill for a while, did the job. I went with a Ryobi because it was cheap on sale fit lots of other tools I carry. For $69. I received 2 batteries drill flashlight charger and carry case. The only reason to retire the Makita is the batteries went bad, cheaper to buy a replacement then the batteries.Dick_B wrote:
Be sure is is 18V, not 12V.
I'll repeat once more ... WHY? :h Provided the stabs' drive screws are clean and properly lubed it takes very little torque at all to turn those screws. Why heft around a 5 or 6 lb drill when a little 12 volt puppy will do the job just as effectively?
OK, I'll go to my room now. :W
Ace hardware had a basic Black & Decker 18v cordless on sale for $24. One battery and small wall charger that plugged into the drill. Bought some for gifts. - coolbreeze01ExplorerI use a 1/2" Milwaukee drill. Came with 2 18v batteries.
- stephensaraExplorerHarbor Freight $20 works great for us
http://www.harborfreight.com/18-volt-38-in-cordless-drilldriver-with-keyless-chuck-21-clutch-settings-69651.html - GuyMExplorerAs others have said, you do not need a powerful drill if you screws are properly lubed. I use a 15 year old 12v DeWalt with very old batteries and a single charge will get me thru several trips.
Guy - GaryWTExplorerJust remember to are just getting the jacks to the ground, you are not lifting the trailer so you don't need much power. I bought the cheapest one with 2 batteries I could find and it stays in the trailer. It can be loud but it is only on for a few seconds and if we are setting up after 8 PM we usually hand crank.
- dodge_guyExplorer IIAnything 18V or higher will work! Make sure to gat the adapters to use with the right size socket. They sell a 3 pack, 1/4", 3/8" and 1/2". Makes doing things around the house easier too.
Someone mentioned an impact driver. These are unnecessary for the scissor jacks and could potentially damage something from the hammering they weren't designed for! Steady turning is what they need and what a driver drill will offer. - temccarthy1Explorer
3oaks wrote:
I use a DeWalt cordless drill just like this one: DeWalt cordless drill
I would not use an impact gun. No need for a hammering affect on the stabilizers. It will eventually take it's toll on the screw mechanism.
X2-- I have same drill.. works great, charge lasts a month of camping, takes just seconds per jack. Bought the socket that fits standard jacks on Amazon. - SAR_TrackerExplorer14.4 Dewalt from my shop does the trick. First, get the trailer a LITTLE nose-down. Then, run the stab-jacks down to just touch the ground with the drill. Lastly, use the tongue jack (that big electric thing with tons of torque!) to level out the rig. Job Done.
44,056 PostsLatest Activity: May 04, 2014
