Keith_and_Lu's avatar
Keith_and_Lu
Corner Jacks
I have a Wildwood Lite which is about 17 years old
I can see where and how I want to attach jacks to the front end of the frame. The rear on the other hand has got the grey and black water tanks right up to the frame rails and the left side has the plumbing connections.
What kind of clearances do I want with a jack?
And I believe that drilling box frames is not a good thing? Welding or u bolts.
Keith and Lu
1 Reply
  • You don't need to mount the stabilizers right at the corners. Just put them where they won't interfere with the tank and the dump valves. As for attaching them, I would not weld them. Makes it too hard to remove/replace a bent one. Most that I've seen are mounted with big self tapping screws.
