If you're not aware, there are screws under the rubber strip on the front of the mouldings. They have probably "pulled" (go into the edge of body side panels) possibly from heat expansion. Only a thought on my part, but this year has been good and hot in most of the country and your travels had to be in hot areas sometime this past year. As to fix, I'd pull the vinyl strips out and check the attaching screws. If they won't tighten and pull the mouldings back to proper position, maybe longer ones and some epoxy in the holes might do it.
