jadatis
Dec 07, 2016Explorer
Once got hold of a pressure/loadcapacity list from Michelin.
For different speeds and for in Mud/sand and on Track.
Will give the picture of it, but in short.
For in Mud/Sand you can use even 50% of the pressure for 20km/12,5m/h on the road, wich then is the maximum speed to use.
Can go as low as 0.6bar/9psi for a tire with 6 bar/85psi AT pressure, ofcource if the load on tire is low enaug.
My conclusion is that at that pressure on road the tire would bare on the sides and not in the middle, but in sand/mud the underground forms that way that it supports the total surface .
But this is my conclusion, of a self declared tirepressure-specialist, so not a profesional tire-ingeneur.
For on track 80% of the pressure needed for 65km/35m?/h on road, wich then is the maximum to use speed.
Here 2 pictures
Here 2 pictures
44,056 PostsLatest Activity: Dec 10, 2013
