- Tom_AndersonExplorerAlso, very aggressive treads, like mud tires, will tend to dig in and get you stuck quickly. A milder all-terrain tread will stay on top of the sand better.
- silversandExplorer
Sam Spade wrote:
If the question is just any old beach that you might encounter, the answer is: Don't do it.
...ya. You'd better know the sand (and tide) dynamics of the beach you want to drive on. The best, is to ask someone who regularly drives that particular "stretch of sand" with a truck camper rig preferably, first.
We've had no problems with stock 245/75 R16 all-terrain tires on the beaches we've driven on the East Coast (this includes driving the loooong St Augustine Florida stretch with the truck camper rig).
I've since gone with slightly wider tires with a taller side-wall (Goodyear Duratrac). - Sam_SpadeExplorerIf the question is just any old beach that you might encounter, the answer is:
Don't do it.
Many beaches won't support even a small car without VERY wide tires. And having a truck camper towed out of the sand is a tricky proposition. - towproExplorerwhat kind of truck camper you looking at? with the Dodge 2500 be enough to truck to carry it? Since you don't have the truck yet, now is a good time to look at the numbers.
- jefe_4x4ExplorerDriving your truck and camper on the beach? It has been done. There are a couple forces in play here. 1. The weight of your camper. 2. How much floatation you can get with stock size truck tires. Coming from a 'jeeping' background, I've experimented with tire pressure on sand for decades on disparate rigs. There are some must haves.
A tall sidewall is good when you deflate for sand. I've stayed with 16 inch tires on wider steel wheels to allow for a longer and wider patch on sand. There are some good to haves. A super single wheel and tire are the ticket for sand running. Here are the 12 inch wide wheels and 365x65R16 (33x15.50R16) super singles I drove into the ground next to a stock 265x75R16 Michelin:
@ 22 pounds of air, the monsters had a 17 inch wide, by 15 inch long footprint that floated on the loosest blowsand: Here is the appropriate sidewall squat: front stock size @ 22 pounds; rear super singles @ 20 pounds. This is about as low as I would want to go.
jefe - 1320FastbackExplorerAir down as much as possibl and keep your momentum up.
Tires as wide as possible will help with flotation but may not be necessary. - Tom_AndersonExplorer
Tcnewbie wrote:
Looking to purchase a Dodge Ram 2500 truck. The size of these tires that are on the truck are 245/70SR17.0E
Will that be sufficient for hauling a truck camper on the beach? Thanks
The most important thing is to make sure you lower the tire pressure until you get a significant sidewall bulge. As far as tire size goes for sand, the bigger the better (especially width). 245s will be marginal, IMO.
44,050 PostsLatest Activity: Sep 08, 2025
