BurbMan
Apr 18, 2014Explorer III
I installed it on my TT 2 years ago...turns out my alignment was pretty close to dead on, but I wanted the increased 2" height that it provides so I could fit LT tires. The Correct Track is designed to allow for alignment mostly for trailers that had the spring hangers incorrectly located from the factory. The axle movement is only possible in 1/4" increments, in my case I was 1/8" out, so adjusting it would have just kept it 1/8" out in the other direction.
Theoretically you could align based on loading, but given how hard it is to get accurate measurements on the alignment, it's not something you would want to do every time you packed the TT.
I know Lippert bought Correct Track and they are pushing it in the OEM market now. There is an OEM version and also the consumer bolt-on conversion that is described in the TL link above. It's worked well for me!
44,070 PostsLatest Activity: Sep 18, 2026
