Terryallan
May 27, 2013Explorer II
I'm sure the jacks, and stabilizers use a good bit of battery. You can minmize that by leaving the 7 pin hooked to the TV with the engine running while you level. That way, you are using the power from the TV to run the jack, and stabs, and saving the battery. Should make your battery last a little longer.
44,055 PostsLatest Activity: Dec 23, 2025
