aarond76
May 27, 2013Explorer
For your water issue:
You have air in the system. Hot water tank was empty and full of air. When you turn the pump on the first thing that happens is the pump fills the hot water heater. In doing so you pressurize the air in tbe top of the hot water heater. Then when you open a cold water faucet the hot water back-flows out of the inlet side of the hot water heater and out the cold side of the faucet. You may have noticed the pump did not come on right away when you opened the faucet like it normally does. Once the pressure drops low enough in the hotwater heater the pump comes back on and fills the hot water heater back up again. Open the hot side of the faucet until all the air is out of the system and this problem will go away.
With your battery issue:
Your described usage should not have drained a battery over a weekend. And like you guessed, they certainly could not recharge it from dead in an hour. I question if the battery is any good.
44,056 PostsLatest Activity: May 04, 2014
