goducks10
May 28, 2013Explorer
I would make sure that the original battery is in good shape, if it is then fine, and get new one installed.
As far as the water pump running. It maybe that it's having to suck air and water and can't do either and that's causing it to keep running. My does the same thing after winterizing. But eventually stops when everything is primed. I couldn't tell you which valve is open or closed but it should only take a minute or less to re-prime the lines.
44,056 PostsLatest Activity: Jan 12, 2020
