djg wrote:
Hey thanks for all the info you guys I know my batteries will hold it then, just maybe not use the humidifier , I assume you just do not fill or put the tank in to not use the humidifier. And again thanks for all the info this is a great forum love all the good info I have gleamed from it.
On my unit, I can adjust or turn off the humidifier. I used it with my single AGM battery.
I find very little loss using the 100 watt inverter, but would use the 12-volt adapter if it is free.
I feel confident that you will have no problem running your CPAP machine with what you have. But the fact is just how much of your available AH do you now use? I will also add, if the AH available are questionable for a night orb two, I really doubt you will die if you do not use the CPAP machine for a few nights.
