Reddog1 wrote:
What I am not clear on is does the machine have a healing effect, or just temporary relief?
As I understand, this is not an age issue.I personally knoe two people between 45 and 50 that have Apnea.
Wayne
Temporary. It only works while the machine is on. True, it's not an age issue. Often considered to be a weight issue, as excess weight and flesh causes the airway to close when relaxed, as in sleeping (obstructive sleep apnea, or OSA). The CPAP (Continuous Positive Airway Pressure) forces the airway open, allowing unobstructed breathing. So the only potential "cure" is losing weight, or surgery to reduce the material blocking the airway.
