- Kayteg1Explorer IIGive us bigger picture where it is located.
Ladder might be coincidence, or last straw, but I bet my lunch it is stress-related crack.
You should investigate and reinforce the frame before patching the crack.
Just for crack covering - house siding caulk is good.
I have good experience with THIS ONE - thedavidzooExplorer IIWe have used this product several times before on fiberglass, etc. with great results.
Marine-Tex epoxy
https://www.amazon.com/Marine-Tex-Standard-RM305K-B-White-Bagged/dp/B07NYBKN51/ref=sr_1_10?dchild=1&keywords=marine+epoxy&qid=1601150131&sr=8-10 - FreepExplorerI haven't heard of a stop hole before. Thanks.
Yeah that's above the upper right corner of the kitchen slide out. - joerg68Nomad IIILooks like a stress crack to me as well. Where exactly is it located? In the corner of a slideout cutout?
If it is indeed a stress crack, just filling/covering it will be a band-aid fix only.
The reason behind it may or may not be harmless.
For now, I would probably drill a stop hole at the end and cover it with sealant. Then, keep an eye on it to check if it opens up again or moves. - FreepExplorerCould be a stress crack. A ladder was on the camper and then the jacks were lowered. Heard a crash and saw the ladder go down.
Discovered the crack days later. - Kayteg1Explorer IIThat looks like stress crack, not hit crack?
- FreepExplorer
joerg68 wrote:
How about a picture?
If you don't know how, try this: http://photoposting.is-great.net/?i=1
- Kayteg1Explorer IIFiberglass is easy.
- joerg68Nomad IIIHow about a picture?
