sleepy wrote:
Remember if you use something that doesn't work you'll have to clean it off later... and that will be harder for you to fix than the mess you're in now.
All things that appear to be plastic aren't... for a "glue" to work it has to disolve the parts slightly then evaporite leaving a solid joint.
Some "plastic" like materials can only be welded with hot air guns... and the stuff in your pictures look like the "weld"type...
Phone the factory and ask them what they use... (and why)
best of luck to you
sleepy
that was going to be my suggestion also. give them a call down in yakima and ask. i have called a couple times and have had great customer service. i know one or two have not had good service but that has not been my case.
