I also turn off the pump when I leave camp for the day.
btggraphix wrote:
Good luck Matt! Two weekends ago I had a "Bam!" and then a "hummmmmm" and a muffled sound of faucet running. Ran to the water pump switch to turn it off. Turned out to be a water line to one of the kitchen faucets had burst and was pouring out inside the cabinet and running out more or less the bottom of the camper. Boy would that suck if it happened when you weren't around. Good reason to always turn off the water pump when not in use.
