boosTT's avatar
boosTT
Cracked Bathroom Mirror
The bathroom vanity mirror cracked when someone tried closing it with too much force.
How can I replace the mirror? It looks like a white plastic section is stapled to the wooden frame that sandwiches the mirror in place. I'm afraid that I will break the replacement mirror attempting to reinstall the staples.
  • Community Alumni's avatar
    Community Alumni
    Not applicable
    When I swapped mine out, I caulked the mirror into place with some crystal clear bathroom caulk that I had. If you use the crystal clear stuff then you don't have to worry about making it look neat lol. The old mirror was originally caulked into place.
  • sch911 wrote:
    Carefully disassemble it. Clean it. Then install the new mirror with caulk (perhaps sillicone). Use Gorrila wood glue to hold it back together.
    Good idea. Thanks
  • Use an electric stapler, they don't transmit force in the same manner as a hammer would. An electric or air stapler is likely how they built it to begin with.
  • Carefully disassemble it. Clean it. Then install the new mirror with caulk (perhaps sillicone). Use Gorrila wood glue to hold it back together.
