rbrumm's avatar
rbrumm
Cracks already?
Any suggestions? I found one on the window cover too.
  • Don't panic yet, how deep do they seem ? Boats get those all time, on the surface gelcoat, they're called spider cracks. From a google on fiberglass spider cracks
    Spider cracks are small, hairlike cracks that appear on the gel-coat of boats. They are also referred to as "crazing". These cracks are generally cosmetic, and indicate flexing of the hull. Sometimes, however, spider cracks offer a path for water to get into contact with the fiberglass structure under the gel-coat. Prolonged contact with water can cause blisters. It is very common for older boats to show signs of spider cracking, as the gel-coat layer was often very thick. The thicker gel-coats can not withstand flexing well.
  • It is on the rounded section of the nose of the trailer.
  • Drill a small hole at the end of the crack and fill with resin or modified/colored resin.
