mosseater wrote:
bobndot wrote:
Even if the slide is on the opposite side of the cracks, anytime I have seen this happen is when people tried to level the TT once the slide was open.
You level it, stabilize it, then open the slide.
After reading one of the previous posts on this, I agree it's probably a weak spot in the build and that's where it cracked from the TT being stressed.
I won't disagree that the majority of trailers are nothing but varying degrees of junk, but if you look at most dealer lots, there are a lot of trailers with the slides deployed and no stabilizers down. I think if this were a root cause there would be a lot more cracks in siding than there are. Sunnybrook had a known issue and the OP has one of those units. The screw went into the siding and nothing else. That's his root cause. I've put my slide out without stabilizers many times since the repair without any negative effects.
I'm not debating what you said regarding this unit. :) I think my wording in my post might have been misunderstood.
It has nothing to do with not having stabilizers down and a slide deployed. That can be done without incident.
Its the motion of leveling an rv once the slide is deployed that can cause cracks.
