tonymull
Mar 18, 2015Explorer
Can't remember if Alaska requires shotguns to be plugged for 3 shells or not...better check. I assume you will be using the 12 g version. Neither a 20 gauge nor a 9mm will deter a brown bear. You can buy some bear spray in Anchorage or in Canada. I also carry bear bangers which you can buy in many sporting goods stores in Canada. Noisemaker, loud as a shotgun, fits in your shirt pocket. Probably as much use as a 9mm, which definitely will not penetrate a bear skull...neither will a 12g for that matter but the 12g will crush it without penetrating.
44,071 PostsLatest Activity: Aug 30, 2026
