Gdetrailer
Jul 13, 2014Explorer III
marcsbigfoot20b27 wrote:
Not sure I understand the issue. I have worked as an ASE master tech for a Mazda Volvo dealer (granted not an RV dealer) but still.
If a trailer sits for 5 years and has 50 miles on it, there is no reason to lube the axles. The lube doesn't go bad or leak out.
My trailer gets a squirt of grease every few trips. My boat trailer gets a shot every outing, but it sits in water for 8 hours at a time.
The issue is not always with preventative maintenance or dealer not willing to repair something. Many times a part will just flat out fail !!!! In that case who are you gonna blame?
It is called life. Things happen in life. If your kidney fails, who are you gonna blame?
You can buy a brand new car and have a part fail in 2 weeks, or have that same part last 25 years. It might not be anyones fault.
There is no info on this thread if the OP had to pay or if it was covered. Either way it is not a "disaster".
Blaming an entire rv manufacturer for an axle bearing going bad is crazy. They don't make the axle or bearing, they source it from someone.
The OP is beating their chest in anger since the trailer manufacturer was not willing to reimburse them for "ruining" their trip nor willing to make an exception to a warranty which ran out a month before the disaster happened. On top of that the OP ADMITTED to NOT DOING THE REQUIRED MAINTENANCE spelled out in said warranty.
IF the OP HAD done the maintenance they WOULD have found either a defective bearing or found not enough grease in the bearings BEFORE a disaster happened.
Wheel bearings can and do fail, sometimes it is defects, sometimes it is not enough grease but most often it is LACK OF MAINTENANCE. You do need to pull the drums and check the brake shoes and the drum surfaces. This should be done on a yearly basis regardless of how few miles been driven.
In PA we have to get a annual safety inspection, this inspection REQUIRES the mechanic to PULL TWO drums (one on each side) to inspect the brakes. I tend to pull all four before the inspection just to make sure it will pass. I find that is a good time to clean, inspect and repack the bearings.
While it stinks to be broke down, the manufacturer is not guilty of being negligent to ensure quality of said bearing since it MADE IT PAST the warranty period. The manufacturer is done with their end of the obligation, end of story.
The OP did not make their case any better by admitting to the manufacturer they did not do any maintenance. I don't blame the manufacturer for not giving any "goodwill", heck they would go out of business if they "offered" free repairs for the LIFE of said trailer.
Folks like the OP assume you simply buy a RV, roll it off the lot and you never have to do anything to it ever.. Most likely the OP will be back in a year or so complaining about water damage from leaks and how cheap the manufacturer was to not cover them.. Which is another maintenance item which NEEDS to be done but most likely will not..
Frustrating, sure, but life changing, devastating or ruining a trip.. no.
If you can't handle some ROUTINE MAINTENANCE every 6 months to a year OR a POTENTIAL BREAK DOWN then you better sell the RV and use Hotels.
OP, fix it, maintain it and move on. Life's to short for this nonsense.
I think this thread probably should also hit the Moderators cutting room floor..
