nomad297
Jul 14, 2014Explorer
SprinklerMan wrote:
Why would you remove the brakes from the backing plate for a wheel bearing problem ? And it looks to me that there is a grease fitting on the end of the axle shaft for the ez lube axles . Cant tell for sure . Unless it was cleaned , that spindle looks awful dry to me .
And why is the tire removed from the rim? All of this to replace a bearing?
Bruce
