marpelExplorerMay 15, 2018Cruise ControlI travel to/from BC and Denver quite often (Sierra, 6.2L) sometimes towing a smallish (under 4000 ibs) trailer and sometimes, not. I travel the major highways and, depending on whether the trailer is ...Show More
Grit_dogNavigator IIIMay 17, 2018And tow haul doesn't cause higher rpms when cruising unless they're needed. And you said you're downshifting as needed, so virtually no difference.
Related ContentCruise controlLost Cruise ControlSway ControlCRUISE CONTROLCruise Control Downshifting
