BertP's avatar
BertP
Cruise Controls
OK, technically this probably isn't a TV issue but it has been bugging me so I thought I'd post and see what responses I get.
I used to own a couple of different Chev TV's. Both were D/A's and now I am on my second Dodge. What is driving me nuts is the "resume" behavior of the cruise control.
In the Chev's, if I had my cruise set for 100 kph and had to stop, upon resuming - even from a very low speed like 30 kph - the cruise would accelerate my truck back up to speed at a very rational, realistic acceleration rate. In my Dodge, not so much. Hit resume at a speed that is even a few kph or mph below the set speed and it goes into drag race mode. RPM jumps to 3000 and the truck takes off like there is no tomorrow. It is ridiculous.
What experience do others have? Am I dreaming about how my Chev used to behave? Marty, you have basically the same truck I used to have. How does your cruise behave if you hit resume when you are 10 or more mph below the set speed? Is this behavior configurable on the Chevs? What about Fords?
Thanks
Bert
  • donn0128 wrote:
    Transmission programming, crusie control programming, engine torque all play into the equasion
    OK, so are any of those factors under your direct control? For some reason, I have in the back of my mind that I could change the programming of my Chev to specify how aggressive I wanted it to accelerate but I'm not 100% sure on that. But, both of my Dodge's would put you in the back seat if you hit resume and weren't prepared for it. My dealer says that it can't be changed :-(
    Bert
    A very correct answer. ^^^^^^
  • My F-350 accelerates at a reasonable pace. But I have had vehicles in the past that used the drag racer mode. Seems like my 96 Burb did that.
  • Transmission programming, crusie control programming, engine torque all play into the equasion
