Grit_dog
May 13, 2019Trailblazer
Whatever year truck you're hypothetically talking about, there are no additives needed for anything.
Engine oil in the engine, diesel in the fuel tank, gear oil in the diffs, ATF in the trans, tcase and hydro pump and brake fluid and washer fluid where they go.
The only "additive" I would consider is 2 stroke oil to older pre-ulsd trucks to help injector life, but even that is suspect.
OR, you can buy fuel treatment for every tank and that Archoil **** for the engine and super luber duty additive for the diffs. Truck will run the same.
44,071 PostsLatest Activity: Aug 16, 2026
