down_home's avatar
down_home
Explorer II
Dec 10, 2020
Recording maintence
Perhaps most do this already but..on the fuel filters and oil filters, with black felt tip marker put the date it was changed. Heat didn't burn it off our oil filter. Also on the oil filter for the generator.Since you change the air filter at the same time, whether it needed it or not,we did. A tag on filler neck of coolant tan survived too,but wasn't hit with a pressure washer. Wouldn't hut to put a tag on the coolant filler neck of the generator either.Perhaps they make a small tag that is a bit tougher than paper, though.
And the water filter, well don't want to write on the housing but a tag there too.
We have a log book and one for receipts but I always ask them to mark the filters.
If I could figure out how to label the tires I would....because time just flies and first thing you know it was six years ago hen you put on those tires.
And it was year before last, not last year you changed the fluids and filters. and greased the joints etc.
