Cummins12V98
May 19, 2019Explorer III
Grit dog wrote:
12V you reccomend amsoil because you now know it’s a Ram?
Because you know that stuff don’t work if it’s a Cummins in another brand? (Which isn’t really possible if you understood the context of the OPs post.)
Like I’ve said before , the intentional, overtly literal interpretations by some here are sooo amusing. Very akin to my little ones interpretations, but now that he’s almost 13, he’s actually grown out of that phase...
What does what I said below have to with your comments above??? I already "ASSUMED" it was a RAM truck and just wanted to know what truck it was year etc. You have anything better to do today???
Now that you have mentioned what truck you have.
I prefer AMZ/OIL products. I prefer their oil filter also as it's made by Donaldson. The FleetGuard strata pore is a fine filter the Donaldson is simply better.
I run full 15k oil Changes with good Blackstone reports to back it up.
I use Mopar, FleetGuard or Racor for my fuel filters, Racor only makes the under bed filter. FleetGuard makes the engine mounted filter and air and oil filters that can be labeled Mopar. DON'T use off brand filters!!!!!!!!!!!
The MOPAR oil filter does NOT have the synthetic Stratapore filtration. Personally would NOT use the Mopar oil filter unless doing short oil changes.
