spoon059 wrote:
FYI, your truck won't go into limp mode. The countdown timer will stop long before zero and nothing happens. Mine was a faulty sensor as well, if I remember correctly, and replaced quickly and painlessly under warranty.
He was down to 23 miles ,and counting. So I don't believe every case is the same.
I have went into the countdown twice, and as you say the countdown went away, and nothing happened, other then the check engine light remained. But it never got close to 23 miles.
Both times ,there was nothing wrong, threw a P207F code ,bad DEF. DEF was checked by the dealer, and was okay , truck was reset ,flashed whatever. No faulty sensors, nothing other than a very glitchy emission system. Have had no other issues since the SCR recall, if that had anything to do with it, have no idea.
Now if the dealer could get some water pumps, I can get THAT recall done.
