markm's avatar
markm
Curb wt 2018 Chevy 3500 SRW CC standard bed
Hi all: looking for the actual wt curb wt (2 passengers, full fuel, fifth wheel hitch) on a 2018 Chevy or GMC 3500 CC 4WD SRW Duramax standard bed. I am trying to determine the max kingpin wt for this truck, which will then determine the next fifth wheel trailer.
I found GM source listed the curb wt at 7548 lbs. Probably no passengers, fuel, or fifth wheel hitch.
Thanks
  • 4x4ord's avatar
    4x4ord
    Explorer III
    My 2017 f350 short box srw 4x4 diesel weighs 8120 lbs... Includes 3/4 tank of fuel; B&W hitch; no driver or passengers. So if you remove the hitch and fuel you might be about 7800 lbs for an aluminum Ford. The weight you were given isn't going to be too far off.
  • That's about right - or at least within a couple of hundred pounds.
