Jimh425 you are correct the slides have been changed and thats why the scaling looks off other then that everything else is on. Yes the camper will be taken on and off as we set up camp. We typically stay 1 to 8 weeks at a site. anything under that I wouldn't be taking the camper off.
I have 1 slide mechanism built already and tested works mint! all Aluminum and the 8ft slide can be pushed in & out by hand very easily after pulling the release. The slide moves in and out on a screw mechanism and the floor drops flush once its fully extended. there is no adjustments to the slide left or right only up and down. less problems this way.
