- mountainkowboyExplorerWe use the **** out of it.....for EVERYTHING.
- jaycocreekExplorer IIDawn dish soap is the only soap you need in your TC..Great for fleas and ticks for your pets...
Good stuff! - towproExplorerI am going to try to spray it on the awning on my open range, then role the awning up wet for a couple hours. My awning has not been white for years. I even have shirts with bleach marks on them from trying to clean it.
- mkirschNomad II
downtheroad wrote:
Works great for washing the roof too, but Dawn makes it real slippery up there so be careful......(maybe wear spiked golf shoes).....:B
Helps if you rinse it off... - ReneeGExplorer
Better than rubber roof cleaner? - downtheroadExplorerWorks great for washing the roof too, but Dawn makes it real slippery up there so be careful......(maybe wear spiked golf shoes).....:B
- ScottGNomadThe "trick" the OP wrote of is to put a few drops of Dawn in the water you dip your finger in to smooth the caulk. I find it works well enough just to use the water alone though.
If you really want it to look clean, mask the area with tape before caulking.
It also does a great job for washing vehicles but as mentioned above, it also removes wax. - donn0128Explorer IIFew drops of Dawn in a squirt bottle stops stink bugs in their tracks.
- sonuvabugExplorerIf using Dawn for washing your vehicles, keep in mind it is a grease cutter so if you have it waxed, Dawn will remove the wax.
- WyoBullExplorerI have been using Dawn dish soap for years to wash all of my vehicles, including my camper. It works great.
44,070 PostsLatest Activity: Sep 18, 2026
