You guys are the best I appreciate the responses. My camper has a shield underneath it to protect from dust /rocks while traveling. I don't know if theirs plumbing underneath it. I do know it has the low drain lines . So once I put it back into storage mode I have no trouble running a heater inside the coach. But wouldn't the outside lines be a problem or would I just have to drain them and than everything inside would be fine ? Basically I'm trying to say the plumbing is mainly inside right ?
The reason I don't want to add antifreeze back is because I had a hard time doing it the first time. The hose I have to use where it gets sucked into the lines by the pump for some reason is way to short. I had to dump he antifreeze into a cat litter bin and angle it while my wife stuck the hose in it. It was quite the production. The hose isint long enough to stick into the antifreeze botttle. It's a shame they made it so short . I wanna do that only was a year if possible lol
