star6443 wrote:
My camper battery is completely drained, dh unplugged weeks ago for unknown reason. I need to hitch up any suggestions? Other than finding a battery charger. I am now plugged into shore power, should the hitch run if I plug into truck? It doesn't. :(
Any trailer I've owned the converter alone with the trailer plugged into shore power has powered the tongue jack, slide, or power awning - no battery needed. Some large slides may require the battery, I couldn't say as I've never owned a large slide, but the tongue jack should certainly work with the converter supplying power to it. Obviously anything wired through a battery disconnect switch won't work when the switch is turned to the off position.
