WAM
Apr 13, 2014Explorer
Dead jack motor
These Atwood camper jacks must be 9 years old now. One refused to budge today and using the manual crank was nearly impossible. I removed the motor off the head and the jack screw now works fine, so...
WAM wrote:SAR Tracker wrote:
Like this one?
Looks to be close, but not quite. The new one has legs at the four corners. Look to be what, 1/2" long maybe? Mine just has little 1/8" stubs in those corners. The outputs look similar.
Worse come to worse, I might be able to cut down the legs to make it fit if everything else lines up.
