adamis's avatar
adamis
Nomad II
Sep 29, 2020
Decal Removal on Bigfoot / Fiberglass?
My Bigfoot camper is approaching 20 years old and the decals are not in the best condition. I'm considering removing them entirely at some point and having the entire exterior waxed and polished.
Has anyone else removed the decals on their fiberglass camper and if so, do you have pictures of what the color difference looked like between what was exposed to the sun and what was under the decals?
  • I've been thinking about doing it for a couple years. I just pulled the cover off the camper an hour ago and may experiment soon. I do have a Porter Cable random orbit polisher and some compound. May try 3M Premium Fiberglass Restorer and Wax first though.
    I read somewhere to be careful with a heat gun.
    I also would like to hear if someone else has done it. There is a Bigfoot Facebook page, I might post on that.
  • It'll be noticeable up to about 20' away depending on how good of vision you have.
    Cut and polish will help, but not 100%.
  • I removed the decals on the front and rear of my 5er after about 6 years because they were cracking and peeling. Some came off fairly easily with a heat gun and plastic scraper. Others that were cracked more I had to use a 3M Eraser Wheel. And then 3M Adhesive Remover on both areas to remove the remaining adhesive.
    After removing the decals, there was a distinct ghost image of the decal shape. That area was still shiny whereas the other areas were dulled. But since I replaced the decals with new ones, that was great for positioning the new decals. Didn't take pictures.
