MM49 wrote:
Engineer9860 wrote:
MM49 wrote:
The Ram will pull a TT much better that the Chevy. The Ram's coil spring suspension uses both sway bar and a pan hard bar. These components limit the lateral movement in the rear suspension. The coil spring suspension will eliminate or greatly reduce sway.
MM49
Are you for real?
Yes I am!
I pull 9500lb TT with a 2014 2500 coil spring suspended RAM. I experience Zero sway,passing vehicle push or any disturbance. The coil spring suspension preforms much better in every way than the leaf spring suspension.
MM49
I tend to believe a 5 link suspension could be more stable over a leaf spring setup and your the first I've read with these improvements.
