wtmtnhiker's avatar
wtmtnhiker
Def Fluid LIfe
Hi all,
My 2013 Duramax has been sitting in my garage since last Oct. Should I be worried about the DEF fluid degrading and possibly causing problems when I hit the road this month? Couldn't find much info about it thus far. They say the shelf life is 2 years but not sure if that applies after it's put in the truck. I've been using Blue Def from Walmart. I think the garage temp briefly got below 30 as the lowest temp.
  • Doesn't matter if stored or in the tank as long as it's not exposed to high temps (as mentioned) or UV light.
  • Thanks it sounds like it'll be okay as long as it hasn't been stored in too hot a temperature. Not sure if it matters if the DEF is in the original container or sitting in the truck tank.
