- Retired_JSOExplorer III keep a jug of Blue DEF in the spare bedroom. Because, it degrades with heat and sunlight.
According to Cummins
Q. What is the shelf life of DEF?
A. The shelf life of DEF is a function of ambient storage temperature. DEF will degrade over time depending on temperature and exposure to sun light. Expectations for shelf life as defined by ISO Spec 22241-3 are the minimum expectations for shelf life when stored at constant temperatures. If stored between 10 and 90 deg F, shelf life will easily be one year. If the maximum temperature does not exceed approximately 75 deg F for an extended period of time, the shelf life will be two years. - Ron3rdExplorer III
Cummins12V98 wrote:
dedmiston wrote:
Yes.
I also always keep a couple jugs of DEF from Walmart in the bed of my truck. Their prices are hard to beat. I remove the spouts from the jugs and put those in the back seat of the cab, because they poop out in the sun.
It supposedly has a 6 mo shelf life
I never buy unless I’m getting low.
Our local WalMart goes through A TON of their DEF so it's always fresh. - Me_AgainExplorer IIIIn 52000 miles all DEF has been Peak Blue DEF all but one from Wally World. The one not from WM was from a Loves truck stop in the middle of NV.
Chris - Cummins12V98Explorer III
dedmiston wrote:
Yes.
I never buy unless I’m getting low. - dedmistonModeratorYes.
I also always keep a couple jugs of DEF from Walmart in the bed of my truck. Their prices are hard to beat. I remove the spouts from the jugs and put those in the back seat of the cab, because they poop out in the sun. - notevenExplorer IIIDEF can also be found at Class 8 truck dealerships, construction and ag dealerships.
Those industries haven’t figured out how powerful and efficient new gasser engines are :B - Ron3rdExplorer III
naturist wrote:
Get DEF wherever it is cheapest or most convenient. The composition is spelled out in Federal regs. There is NO allowance for “secret sauce” or any amount of deviation. It’s made of two of the cheapest compounds known to mankind, so incentive to make it cheaper is lacking, as well as outright illegal.
Correct; unlike motor oil, there is no good/better/best, it must meet a standard and it's all the same, like buying isopropyl alcohol at the drug store.
Buy the cheapest you can find. I use the WalMart SuperTech house brand at $7.88 per 2.5 gal jug.
I've used the truck stop in the past and with the small amount I use, it's just not convenient for me. - Grit_dogNavigator IINope, I don’t. Because my truck doesn’t need def....but if it did, or I’m filing up a work truck I d buy it at the pump if it was convienent.
- naturistNomadGet DEF wherever it is cheapest or most convenient. The composition is spelled out in Federal regs. There is NO allowance for “secret sauce” or any amount of deviation. It’s made of two of the cheapest compounds known to mankind, so incentive to make it cheaper is lacking, as well as outright illegal.
- Cummins12V98Explorer IIITraveling I mainly use the truck Stops and do fill my "RAM" with dEF at them. Otherwise I pick up PEAK DEF at The WallaCost.
RAM since 2013, Dodge died at the end of the 2012 model year.
44,048 PostsLatest Activity: Aug 21, 2025
