dedmiston's avatar
dedmiston
Moderator
Jul 15, 2016
DEF Issues
I drove a RAM 2500 diesel for 12 years until I upgraded to a pre-owned 2014 3500 diesel earlier this year. I knew nothing about DEF when I bought the "new" truck in March. My first introduction to DEF was when I saw the extra gauge on the dash and the filler inside the gas cap door. Well whadda ya know? I caught on quickly enough and filled the DEF tank as needed.
Fast forward to last week...
We left on a trip last week to go white water rafting up on the American River up in the gold country. I noticed before we left that the DEF level was just below 3/4 and didn't give it much more thought. Off we went.
Coming down the back side of the Grapevine I noticed that the check engine light was on and the DEF gauge showed it was empty. Oh no. I stopped at the next gas station and bought a few jugs of DEF to refill. By then a message popped up and told me "5MPH Max Speed in 150 mi. Service DEF System. See Dealer."
Swell.
I managed to get about three gallons of DEF into the tank before it overflowed. The needle stuck at Empty though.
So we limped to Bakersfield and spent the night at an RV park down the street from the Dodge dealer. The next morning the folks at the Dodge dealer took four hours to check it out and declared that everything was just fine and the message was bogus. They reset the errors and sent me on my way.
We had about five hours to go from there. About an hour away I noticed that the needle was down to 3/4 tank. That was fast. I tried to add more when we stopped for fuel, but the tank was full and I couldn't fill it any more.
Over the next few hours the needle fell quickly until it finally got past the red again and gave us a similar message: "Speed Limited to 5MPH in 200 mi. Refill DEF."
Luckily our destination was only about 20 miles away, so we got to camp and sent in to the closest dealer the next morning for service. They diagnosed it and said that the DEF pump was faulty. They replaced the pump and the sensor (part of the pump).
The service writer there was much more knowledgeable than the one in Bakersfield. She said that the sensors aren't mechanical, they're sonar. The sonar sensors run into trouble if you refill the DEF too soon.
"DEF level sensors operate off a sonar sensor and must see an air gap before level will actually drop. Filling the tank before it reaches the 1/2 way mark, we have seen issues with it detecting incorrectly and can set a fault in system. To prevent this we just recommend not filling the tank unless it is between the 1/4 and 1/2 mark. The only other thing that I can think of that might really help and prevent possible issues is to ALWAYS use your exhaust brake. Make it a habit to turn it on as soon as you get into the vehicle. This will help to reduce carbon build up in the exhaust brake and keep it working properly... saves your brakes."
I thought I'd check here and see if this jives with everyone's understanding. And if so, are there other things I should keep in mind with the newer diesel?
I also noticed on this trip that almost all of the gas stations along I-5 and I-99 sold biodiesel instead of good old #2 diesel. Is this kosher? Anything I should be concerned about?
