Impact on the quality of DEF per Transliquid technologys LLC
Q. What is the shelf life of DEF? A. The shelf life of DEF is directly related to the ambient storage temperature. DEF will degrade over time depending on temperature and "exposure to sun light". If stored between 10 and 90 deg F, shelf life will easily be one year. However, if the maximum temperature does not exceed approximately 75 deg F for an extended period of time, the shelf life will be two years.........
IMO....If you don't drive it much don't fill it all the way just put in a gallon at a time so you're always running good def.
