jjr1314's avatar
jjr1314
DEF Shelf Life!
Just a quick tip for those that are new to Diesels with all of the newer emission controls. DEF apparently has a shelf life and using anything other than DEF bought from the dealer may void your warranty.
I have a 2011 Duramax and recently had a message on the DIC stating Diesel Exhaust Fluid Quality Poor. Unfortunately I ended up in Limp Mode before I could make it to the 1st Dealer.
I tried to get a service appointment at the dealer I purchased the truck from but they were backed up with recall work. So off to Dealer #1. Dealer #1 was absolutely no help what so ever. They stated that since I had used DEF from an Auto Parts store and not from a dealer they would not cover any of the repairs under warranty. They also said the only fix was to replace the entire DEF Tank to get rid of the supposedly bad fluid. I said no way, put my truck back together and I would be by to pick it up.
Dealer #2 (where I purchased the truck from). Sorry if I am breaking forum rules here but when service is good I think we owe it to them to give them credit. Dave Sinclair Buick GMC is the place I will go for service from now on. I did some research prior to the appointment and was ready to argue my points to them. No need to. They said that they have in the past had problems with GM covering DEF problems in the past but would do everything they could to get it covered. They even said they would contact a regional GM Service Rep on my behalf. They called today and said that it was covered. They tested the fluid and it was good. Turns out it was a bad NOx sensor. It was not the fluid after all but I think I will be keeping better track of where I purchase DEF from.
