2BLAZERS's avatar
2BLAZERS
Define ''All Season'' campers please
So what is everyone's view point of ''All Season'' qualified campers?
Reason I ask is this weekend we camped up at Leavenworth, WA in our 2011 Arctic Fox 1150. We kept the furnace heat on from leaving home and it is still on (at least 65 degrees). Kept cabinet doors open and when plugged in we kept a space heater on (to save propane but leaving the furnace on too) But we still ended up with the cold water for the sink frozen up where the line runs under the shower (dry bath) and the water tank drain line froze up....it was 5 at night and 20ish during the day. And the camper was really drafty and the floor was super cold all the time..... are we expecting to much?
No damage, we just aimed the space heater under the sink which has a hole where the lines go under the shower with the water on and it worked pretty quick to unfreeze. Used the heater again on the water tank drain and got it all drained out at home last night so we could winterized again....more just a hassle. Also the wife is not to happy about the campers warmth feeling in cold weather with a name like Arctic Fox....
Should we really have to insulate more an All Season Camper and seal it up better?
  • 'All season camper' might mean comfortable in San Diego but not necessarily in WA. Or, if you're willing to travel with the seasons. ;)
  • I think "all season" means anything from 110 degree heat to -20 degree cold, you can survive..I have extra Owens Corning in the walls and ceiling, bubble wrap for a barrier along with enclosed underbelly and finally insulated windows. I stay warm in winter and cool in summer. I had to order my camper with these extras but well worth the extra money...almost all units sre only slightly equiped for extreme weather
  • In theory, you "shouldn't" have to make additional improvements, but in practice, you probably do. Or at least I think every camper tends to have a weak spot or two, weather it be a single line that runs too close to the side, or a pocket somewhere that doesn't get any real air-flow, or a wide open gap somewhere to the outside. It only takes one little mistake in assembly to cause a problem. I've been cutting into my camper all over the place for the last 4-5 years to be able to see and access everything as much as possible, and be able to correct things, or at least access things in the case of a problem. I listed my basement work and HVAC/Insulation changes as the most important "mod" I've done on the camper and still feel that way. Not too "sexy" a mod, but effective? You bet! If you are going to be serious about winter camping in a large TC I think it is a very very important step to take.
  • And with the furnace on the whole time, there is a fan that moves warm air into the basement 24/7. I did check and it was working...
