Curiousraven's avatar
Curiousraven
Determining VIN or Serial number on 1968 Travel Queen Camper
Hello! I'm new to the forum and am seeking how to determine the serial or VIN number for a 1968 Travel Queen truck camper that was gifted to me. There's been a few issues with licensing (hence the need for (S/VIN) and the camper itself needs work. I've checked every cabinet and nook but the only two plates or tags that I can find are next to the door.
At eye level there is a green plate with lettered boxes. One of those boxes is marked "S" and has 3 numbers following it with another unmarked box trailing behind. The other plate is near the lower left hand side of the door and bears the numbers from two of the boxes on the green plate and are spaced with a letter (in this case "J"). From what I have seen the numbers in the "S" box are unique to each trailer so it must have to do with some form of identification?
Thanks in advance!
  • I unfortunately can't help with your question, but I'm wondering if it accidentally posted in the wrong forum. Are you talking about a travel trailer that you tow behind another vehicle? Or are you asking about a truck camper that slides into the bed of a truck?
    If it's a truck camper you might want to ask a moderator to move your question to the truck campers forum. The truck camper group is definitely active and you should get you answer.
    Good luck with getting an answer and welcome to the forums.
