Big_Love's avatar
Big_Love
Dexter center drive slide motor
I have a 2010 Rockwood 2604 with one large slide. It does not have any holes to access the slide motor from the outer body of the trailer.
I believe this slide has a Dexter center drive unit which can only be accessed by opening a flap on the underbelly cover, exposing the drive motor and manually accessing a recessed nut on the motor with a socket wrench to turn the motor. It also requires the motor brake to be disengaged by using a 9-12v battery connected to two small wires going to the motor brake.
Does anyone have any experience or photos using this procedure if the slide won't operate with the cabin switch? I know to check the 30A fuse for the slide first and make sure house battery is charged.
