djtkach's avatar
djtkach
Diagnose electrical issues
I believe I have two related electrical problems, the second one likely self inflicted by trying to work around the first one.
Part 1: Went to pick up the TT from storage today, installed the battery (fully charged), tried the tongue jack and nothing. Connected to the TV power and still nothing at the jack. Brakes and lights on TT work.
Connected to shore power and lights and appliances in TT work, but jack is still dead. Tested jack fuse and found it is good.
After deliberating, I noticed and jumpered this, which is mounted on the frame right behind the battery box and is connected to the battery terminal:
Whatever this is, the jack worked while the two posts were jumpered. I hitched up, removed the jumper, and came home.
Part 2: Got home, re-connected jumper, expected jack to work and instead, got nothing. Connected to shore power, still no jack, and now only appliances work in TT, not lights as previously before I did the jumpering.
My guess is whatever the part in the pic is, it was wrecked at the outset of my day, and that by jumpering it I wrecked something else in the line somewhere. Any suggestions on where to go looking from here?
Thanks!!
DougT
  • Sounds and looks like a bad 12 volt circuit breaker. Others will follow with additional answers.
  • Cant tell for sure, but if it is connected to the - battery terminal it means a bad ground. If it is connected to battery + then it is a circuit breaker. They are cheap, so dont panic, just go buy a new 30A resettable breaker, install it and go camping.
  • Bad ground. Disconnect the rusted terminal in the picture & clean. The battery is also probably very low, if not completely dead. The tongue jack is self-grounding, & there is probably not enough juice in the battery to power it.
