- dodge_guyExplorer IIIf its like Ford and Chrysler you can change the reading for the speedo so it reads properly. Im sure it can be done on the GM`s. However its in the PCM.
- 6_6_OilburnerExplorerThe tire size is not programmed into the IPC, ( Instrument panel cluster), I would GUESS incorrect tires size or possible previous aftermarket tuner. Tire size data is in the ECM. I don't know if the dealer tool has a function for modifying that. I'm inclined to think not. The MPG and gallons used may never be 100% spot on, the speedometer should be correctable.
- GordonThreeExplorerThat does sound like incorrect tire size. Yup dealer, or any shop with the right flash tool or whatever they're called should be able to update that. Probably not the cluster that needs programming, more likely a body control or power train control module, cluster being just the display
- Bob_VaughnExplorer
6.6 Oilburner wrote:
Any independent shop thats halfway up with the times should be able to program a Cluster. What are you trying to accomplish?
My numbers are always wrong, MPG is always high, MPH is always low. Gallons remaining always wrong.......I think the wrong tire size was programed into it prior to being built... - 6_6_OilburnerExplorerAny independent shop thats halfway up with the times should be able to program a Cluster. What are you trying to accomplish?
- GordonThreeExplorerReprogram in what way?
44,068 PostsLatest Activity: Jun 21, 2026
